My events page is no longer showing a picture of the event. It shows a picture of the camera only. Anyone know how to fix this?
You must be using a 3.0 version of the app and that is how it is now I guess? I am still using iOS 2.50.9 and the events have pictures.
No the 3.0 app shows pictures. @sherryschirmer5 the only time I’ve seen that in the 3.0 app is when my phone has a low wifi signal (out in the garage etc). If that’s not your issue, try clearing the cache in the app and if iOS has a place to clear cache try that too (not sure if it does). If all else fails, uninstall/reinstall the app.
NOTE - do not uninstall the app if you are still on the 2.X version. That likely means your device is not compatible with 3.x and you can no longer do a new install of 2.X!!
I would also reboot the phone as well.
