I have the doorbell camera. Is there a way to get notified or alerted in a loud way when motion is detected? I want to be able to use my doorbell camera as a type of security camera through the night etc. Please help! Thank you!
Welcome to the forum @jsica1207.
Do you have a Wyze Cam V3 or Wyze Cam Pan v2?
If so you could create a Rule that states if the Doorbell Camera Detects motion then Turn on the Siren. See the below as an example.
However, I would warn you that you will want to make sure to test sensitivity. As you know, just about anything can be detected as motion at any time.
Auh, thank you for that. I have a cam pan but no siren option. Hmm… this is a bummer.
Must be the V1 then as they have no siren function.
But that would be the way to do it. I do a similar rule for my Leak Sensors.
