More integration of Wyze Cameras with Home Monitoring
The Wyze Cams all have speakers and those that are connected to our Monitoring system should be able to sound sirens when an alarm is triggered. The siren on the Home Sense Hub is not very loud; and a while ago, I set off the alarm without knowing I did until Noonlight called me. If the cameras were also blaring their sirens, then intruders would definitely be uncomfortable with more distributed noise, owners would definitely be aware they had triggered an alarm and if a camera were outside, neighbors would be alerted to the intrusion as well.
We bought a Hub for use as a home security system. We put sensors at all the doors and windows of our 2-story house. If you’re on the main level, you can clearly hear the Hub announce when a door or window is opened. Can Wyze please make a “satellite” annunciator for people with bigger homes to announce actions when your’e upstairs or downstairs from where the Hub is located? Something similar to the Video Doorbell Pro chime that plugs into an outlet would be ideal.
Moderator Note: This separate post has been merged to this #wishlist topic. Please hop up to the top and vote for it.
As long as the volume is adjustable as well as the tone/chime, it should do the trick. We just want to know if someone opened the door, not blast our eardrums.
I was wondering if there could be a way to use the Doorbell Cam wireless Chime as a Security Door Chime and possibly as a Security Siren. I know Certain Cams and Floodlights can be used as sirens. However, my doorbell chime is loud enough to be heard throughout the house. The speaker on the Wyze Security Hub is not very loud so it would be nice if the Door Chimes and Siren could be linked to the Doorbell Chime. This would also allow me to put the Security Hub in a out of the way location so thieves can not disable it as easily.
