Consolidating Cameras to ONE hub; outdoor AND Indoor
I live in an area with no internet, no cable… I use a WiFi Hotspot to connect. Problem is, I have limited seats on the hotspot. Here’s the question… can I pair NOT ONLY the outdoor camera to the Outdoor supplied Hub, but ALSO my PanCams from inside to the hub so that I only have the ONE device (the hub) taking a seat on my hotspot?
Welcome to the Wyze community @kristine.kelly!
Currently only the outdoor cameras can connect up to the base station.
There’s a Wishlist item to allow all Wyze products to connect to the base, but it is set as “maybe later” witch means that it may not be on the top of the list.
Agree w/ @Brlepage The Base unit uses non standard protocol.
There is a NETGEAR 5-Port Gigabit Ethernet Unmanaged Switch (GS305) on Amazon $15. I’ve used an older version of these, very small, dependable, inexpensive and run on 5V @ 3/4 Amp.
If you need an inexpensive router with a DHCP server to allow more connections, check out the
GL.iNet GL-AR150 mini Repeater Bridge, $25.49 (Doesn’t come with power supply)
