Out of the blue, our two bulbs in our dining room staring coming on at around 9:47pm. I can’t find ANY automation setting, vacation mode, etc. that tells them to turn on at that or any other time. This started at the same time two of my cams started setting off their sirens when motion is detected, which I didn’t select nor are any settings selected for that (separate ticket created). Any help would be appreciated.
I mentioned Echo Show in your other topic. If you’re using that or some other third-party integration, then have you checked that platform to see if some kind of automation/routine is activating your lights?
No 3rd party involved.
