I can do the 2 way audio talk using my iphone’s wyze app. So the setup and the speaker/mic in the camera is working well.
But when I connect using alexa in echo show 8, it only bring up the video but the audio is one way. (only from camera to echo show 8 but not from echo show 8 to the camera.
Welcome to the forums! Looks like pulling up the live stream (audio and video from camera) is the only thing that can be done on the Shows and talking back to the camera is not a funtion at this time. I can quadruple check when I get home in a few hours but everything I can find now does not list that as an option.
I have an Echo Show that I can command to ‘show doorbell’. It then displays the doorbell camera - of course it is rotated 90 deg but that is a separate bug/issue.
I have also set up an Alexa routine to do this when the doorbell is pressed.
But, I have not found a way to talk to the person at the door using Alexa.
Alexa ‘talk to doorbell’ does not work
Anyone know a way to achieve this?
Desired example workflow :
Doorbell is pressed by UPS driver,
Echo Show displays doorbell video
I tell Alexa to establish 2-way audio with doorbell
" I say, hello?
Two-Way audio with the wise doorbell is a very basic function that should work with Alexa. It’s amazing that it does not have this capability. I have my wise doorbell set up to display on my TV screen with Alexa, but there is no sound. I hope that wise fixes this very basic function
URGENT - Please review - please add 2 way audio to Alexa skill to provide accessibility for disabled person. I cannot use my hands to “hold to speak” the mic button on the screen so I to use a routine or a voice command to unmute the mic and have 2 way audio. This is a safety issue for me. Please help.
