The floodlights on the Wyzecam Floodlight I installed over my garage stopped working. The camera is fine, but the lights fail to operate. I tried deleting and reinstalling and that didn’t work. Then I tried doing a Factory Reset, and that didn’t work either. Any suggestions? Thanks
After the reinstall, did you reassign the cam to the Cam Plus or Cam Plus Lite license and then reset all the Cam and PIR Activation settings?
Does the floodlight turn on manually?
