I’ve had a Wyze Windows Cam for about a month, and it has worked as expected.
It is running on a Moto G 2025 smartphone, on Android 16.
But a few days ago, any “large” view started displaying a white bar at the bottom, over the Wyze logo and date-time stamp.
In more detail, most portrait views display normally.
But if the phone is rotated to landscape view, whether Live, Events, or SD Card, that white bar appears.
Or, if in portrait view I double-tap to enlarge, that also gets the white bar.
On the Wyze web portal, the views are good.
And, in the Mumu Player Android emulator, on Android 15, running on a Windows 11 PC, every view is good. So the problem only occurs on the phone.
Past discussions of this topic tied this behavior to specific versions of the Android app.
So on Fri 09-04-26 I found I was on 3.21.0.955 (August 31, 2026), and manually updated to 3.21.1.962 (September 3, 2026). But the problem remained.
I have Camera firmware version 1.3.0.52.
I’ve power cycled the camera a few times, and also power cycled the phone, too, for good measure, as the problem seems Android related, but not really tied to a particular Wyze app.
Just to get some formal complaint registered, I did submit a log, just in case it might help the programmers, in case other people reported the same problem.
Are there further steps I should take, or will this get figured out at Wyze?
E.g., trying older app versions, like 3.20.0.941 (August 24, 2026) or 3.19.0.935 (August 11, 2026)?
Or is there some Android graphic subsystem at fault, that might get corrected as the phone gets updates?
