My Wyze Cam v2 stops continuous recording after a fews days. It is running firmware 4.9.9.1851. It is mounted outside under the last part of the roof. I don’t run it in winter, just in the spring and fall. I changed the sd card a few weeks ago and I have the same problem. I always have high endurance sd cards in the cams. This is one is 64Gb.
It is possible because it is facing the street and a lot of cars are detected?
A full format should be a waste of time here since you switched out the sd cards and its multiple anyways. They’d all have to have the same issue of that and that’s so terribly unlikely.
I tried a full format and like said previously, It did noting. I took out from outside and I noticed It is very hot compared to my other ones. It records for two hours continuously and then stops recording.
