Wyze thermostat: What am I doing wrong?
I recently switched from the AC to the heater, I thought I got everything set up correctly, but it’s only heating to 69°F, even though I have it set to heat to 73°.
I know that you can’t just change the Temperature Preference alone, it won’t pick up that change, you’ve gotta update the temperature preferences, save, then delete any/all schedule blocks, and create new ones. So, that’s what I did.
I like to keep it simple, I don’t even use Sleep or Away, just Home - same temperature 24/7. I’m attaching screenshots.
I thought I had it right, but it only heats to 69° and I end up having to ‘temporarily’ set it for 73°, but it seems like that reverts back to 69° eventually (probably 1am).
Any idea what I’m doing wrong?
How do you have the away and sleep set?
You can set the schedule for home / away / and Sleep for it to adjust, including times. If you have away set based on presence then it may sense that you are away. as a test, change the away to match the home and see if gets to 73.
@adam7
What you experiencing may be related to the ‘schedules not triggering’ issues described in this topic Wyze Thermostat Schedule not Holding - Home - Wyze Forum
However, since you don’t need a schedule you should be able to:
  • Swipe up on the main screen to display ‘Controls’
  • Set STATE to ‘Home’ to select your ‘Home’ Temperature Preferences.
  • Set MODE to ‘Heat’
  • Set FAN to ‘Auto’
  • Select ‘Hold’ and then ‘Begin Hold’ to set a Permanent Hold
  • Swipe down and you should see
    • You’re Home
    • Heat to 73
    • ‘Controls Holding’
How away and sleep were set are in the screenshot, but I changed them, to match Home, deleted the schedule block, created it again, and it still doesn’t work, still holding at 69°.
Thanks anyway, I’m going to try TerryL’s suggestion, it’s more of a hack but it might get it to hold the temp I want.
Thank you, I have a feeling this is the best solution. I tried spamoni’s suggestion with no luck, so now I’ve set the “Hold” and we’ll see how it goes.
I’m not ready to buy a better thermostat yet, so the longer I can get this one to work the better, I appreciate your help.
When I woke up this morning, the house was a perfect 73° - your solution works.
Thanks.
Glad to hear.
Keep watching Wyze Thermostat Schedule not Holding - Home - Wyze Forum.
Hopefully WYZE will fix the underlying Schedules Not Working issue.
