Wyze Thermostat Schedule not Holding
Seriously.
Pretty major issue to be ignoring here…
FYI … I am copying and pasting from the email I just received from Support … not sure if it’s just standard responses … would be nice if the Wyze Team provided a more concrete update.
I understand how frustrating it can be to experience an issue with your device, especially when you are hoping for a lasting solution. Please know that you are not alone in experiencing this. We have received similar reports from other customers, and the issue has already been brought to our team’s attention for further review.
Our team is working to address these concerns, and fixes are generally provided through future app or firmware updates. While we do not have a confirmed release date yet, we want to assure you that your feedback is valuable and helps our team identify areas that need improvement.
This is the most generic “response” possible. I am not optimistic. I have only the thermostat; I need to find instructions for replacing Wyze with practically anything else.
If you are looking for a replacement thermostat I recommend Ecobee … more expensive but worth the money for the extra features.
You can read more about my experience in turning to Ecobee for 1 of my 2 locations in this post
I have Wyze cameras that I am sticking with for now … Auto Firmware updates have been turned OFF.
On the other 2 device brands I own (Yolink Leak Detectors and Ecobee thermostat) I can say:
  • I can’t comment on their Customer Service because I’ve never had to use it!
  • I don’t even know if they have a User Forum like this one … their website had videos and info to answer all my questions.
I am monitoring the Black Friday sales to buy a 2nd Ecobee to replace the Wyze thermostat.
Hi everyone, sorry for the inconvenience! The thermostat schedule issue should be resolved for now. Could you please check whether your thermostat is following the configured schedule correctly?
If you’re still experiencing any issues, please let us know. Thanks for your patience!
Hi @WyzeEnTing
I tested by advancing the time of my Sleep schedule block but it didn’t kick in.
There is no new App or Firmware update.
What was changed to make you say the problem is resolved?
Nope.
I added a block to the existing schedule at 3:15pm to change the temp at 3:30pm. Came 3:30, and nothing changed.
@WyzeEnTing
Nope. I just added a new schedule block and it’s still not taking.
This is not fixed, how could it possibly be fixed. No update, no new firmware. Just bs from support saying it is fixed.
Hi @TerryL @james18 @fullerjp @maf49er , could you please submit a log and share the log ID with us? Thanks!
Hi @WyzeEnTing
4:55pm Set up a new schedule block with time 5:00pm
5:00pm New schedule block did not activate.
5:05pm Submitted Log ID 2661630
@WyzeEnTing
Changed schedule to Home at 3:35pm, which did not trigger.
Changed itself to Home at 5:00pm which is the old schedule that does not exist.
Log ID: 2661827
Still not working Log #: 2662186
My Schedules are working.
I tried the procedure below before testing this morning so not sure if WYZE fixed or the procedure fixed the problem.
  1. First run a test to see if WYZE fixed the problem.
  2. If Schedules are still not working then try:
  • Delete all schedules
  • Clear any Hold
  • Settings → Restart Device
  • Exit and Close App
  • Open App and check Thermostat
    • In my case the Mode was set to ‘Auto’ so I changed it to ‘Heat’
  • Create a new Schedule and test
Mine are working again as well after deleting the old schedule and adding new blocks
Hi everyone, we’re sorry for the inconvenience! The issue has now been fixed. Could you please check if everything is working properly on your end?
Thanks so much for your patience!
Mine seems back to normal. Checked it this morning and again after I was out for a while.
Thank you for taking care of this.
Looks to be working on my end, thanks for the fix :grin:
Well, the problem has returned. I changed the schedule yesterday and the changes get ignored.
I submitted a log, number 2671718
I added a new schedule block and it still works.
Did you try
