Helpful tip if using the neutral accessory wire.
On the side you plan to attach to the switch remove the wire cover twisting multiple times in a clockwise direction this will tighten the wire bundle making it easier to slip into the connector without fraying the bundle.
On the opposite side leave it soft (don’t twist) so it connects to the neutral bundle better using the wire nut.
