Wyze sprinkler wireing
Where are the instructions, how to connect the wires to Wyze sprinkler
We to the Wyze community @apboston7!
Have you tried setup in the app? The app does an excellent job of showing you how to set it up. You’ll just need to select your wires on the setup screen.
Definitely try if you haven’t already.
Thank you. I will try the application.
