Wyze Solar Cam Pan Firmware Beta Test 1/14/20206
Version: 2.0.0.2071
What’s New:
  • Improved connectivity stability and resolved an issue that could cause cloud video uploads to fail.
  • Updated to the latest camera SDK version to improve the connectivity quality and resolved the issue that app settings could not be saved.
  • Fixed the issue where unexpected battery drain of the SoC could prevent the MCU from reinitializing the SoC, leading to a device hang.
  • Other bug fixes.
Is this something we could download and flash onto SCP devices stuck in “device offline”?
I have two (out of a purchase of six) that are both stuck. Since there’s no hard reset, would flashing them work?
Welcome to the Forum, @thedarlingmatter! :wave:
I haven’t ever seen Wyze make beta firmware available for flashing, but I think that’s a good question. What troubleshooting have you attempted with the problem Cams?
When I’ve had issues with an unresponsive Solar Cam Pan (and I can’t even tell from the app what the battery status is in that situation), I’ve unclipped the Cam from its mounting bracket, brought it indoors closer to the Wi-Fi source, and plugged it in to charge. While doing that, I hit the Cam’s SETUP button and reinitiate the in-app add device process, then when I get to the point where the Cam is back online I just swipe the app closed to abort the add process. That has reconnected devices for me without requiring a full reset or in-app setup.
