I have a few v1 and v2 sensors.
I do not like notification from Wyze app because it could be too much notification.
However, I want only notification when one sensor is triggered. Can I do that?
Yep, when using the app in each device there should be a set of settings to enable to disable its notifications. Just disable everything but the one sensor you want to receive app notifications from.
