Does the wyze sensor have an iPhone sound alert
Do you mean do you get the normal iPhone basic notifications with a generic sound and pop up? If so then yes? As long as you have notifications on etc…. For some of my motion and contact sensors I have notifications off. ( I don’t need to know every time someone goes into the closet or the laundry room) But I do have a notification on that alerts me to the motion sensor that my dog is at the front door so that I can get to there quicker and get her in and out of the cold quicker and I do have the notification on for the contact sensor on my back door so I know if someone opens it which at this time of the year it’s not supposed to be open at all. So just depends on which ones you want on and which ones you don’t. But you should be getting a notification if you want one. If you need any help just ask
Yes just wanting to know if there’s a sound alert which you stated “yes”
THANK YOU
Glad to help.
