How do you record to SD Card when using sensor bridge?
I have my v2 with the bridge set to continously record to SD. No issues with it also being my camera with the bridge.
Welcome!
Edit: the only thing using the bridge in a cam is that you can no longer daisy chain cameras together with usb cables. Unless the bridge is at the end of the line, but you may have power issues running all that off one wall power unit.
SD card uses an SD card slot. Sensor bridge uses the USB port.
But has anyone tried a USB splitter?
From reading on this forum I think a lot depends on the power to the system, there have been several reports of swapping USB cables/power sources resolving inability to connect problems.
