Wyze Plug Version
How can you tell what Wyze Plug version you are buying on the Amazon page. All the listing say WLPP1. Surely, the can’t all be the old model. A picture of the package is not part of the listing either.
Amazon listings tend to reuse the same base model number in the title, so WLPP1 there does not tell you much. Scroll down to the Product information section and check the Item model number, since the newer 2021 plug is normally listed as WLPP1CFH rather than plain WLPP1. You can also post the question in the listing’s Q&A and ask someone to read the model off the box.
If it still is not clear, buying from the Wyze store directly is the surest way to get the current version.
Welcome to the Forum, @jcpny1! :wave:
What specific listing(s) are you viewing? The one product page I’m seeing that appears to be official Wyze is this:
That one does show “Model WLPP1” in the “Product details” section of that page, which isn’t especially helpful. If you decide/decided to try ordering anyway, then this post might be a useful visual reference:
