Does anyone know if the Wyze App can be setup to send a notification if a Wyze Plug is offline?
I have other smart plugs which remain off after a short power outage, and I don’t even know my Wyze Cams are not working until I happen to check the app manually while on the road. An alert would tell me I need to login and restart a device manually.
Thank you!
Check out this wish list topic
