So I decided to mount my wayze upside down in my basement from a clamp and a magnet. the issue I am having the Wyze doesn’t seem to want to work when it is up there. It works fine when I take it down and use it on a flat surface without a magnet attached.
Anyone else have issues like this? It seems to also make a lot of beeping annoying noises when it is mounted on the magnet.
I would like to think the magnet is not being affecting the components inside. have not had any issues till now.
