Wyze PAN Hard Vertical Limits
Can we have a hard upper and hard lower limit on the PAN V3?
Ceiling fans could be excluded with this simple limit.
I have a use case where the PAN is on a Boat Dock, and the reflection from the water is causing shadows on the beams in the ceiling of the dock, and the camera stays on those shadows unless i turn the sensitivity all the way down - which is kinda useless. And the “Detection Zone” is useless on this camera
One or more fixed cameras is likely going to be your only fix in your situation.
