Wyze Pan Cam v4 firmware update download
Hello!
I am trying to flash the firmware onto my Wyze Pan Cam v4. I looked and noticed the Firmware update isnt available on the website. Can support or someone help me with a download so I can move forward with manually flashing the firmware on my cam?
Welcome to the Forum, @Spirit_Archer! :wave:
Why do you want to flash firmware onto your Cam Pan v4? What firmware is installed in it now and why is that a problem? I’m trying to understand the goal here, because to this point I haven’t seen Wyze publicly offer firmware downloads for flashing Cam Pan v4 or other recent camera releases (which is frustrating to a number of users, including me).
We had some bad weather recently and my camera was stuck with a purple light. Hard reset and power cycling didn’t work. I saw that it may have been an issue with the camera booting and it could be fixed by flashing the firmware onto the camera. As you mentioned they do not offer the download currently. I was luckily able to get it replaced from the store I purchased it from even though I lost the receipt.
I was hoping that someone on the support side would have a file I could use. I was desperate to fix my camera :joy:
Thanks for responding with additional detail. :+1:
Does that mean the Cam’s status LED was purple or that the images had a purple hue? If the latter, then that’s usually an issue with the IR filter being stuck, and sometimes restarting the Cam and/or cycling through Night Vision options, firmly tapping the Cam’s body, or moving a magnet around the Cam can get the filter back into the proper position. If the issue was the former, then that LED color usually indicates an in-progress firmware update. If the Cam wasn’t recovering from that, then I’d probably try removing the microSD card (if one was installed) and attempt a factory reset.
That’s probably what I would’ve tried if the factory reset didn’t work. I would’ve opened a ticket with Wyze Support (perhaps after submitting an app log) to see if they could supply something. I don’t know if downloadable firmware is something Wyze makes available through the Wizards or not, and I don’t know why they haven’t been posting flashable firmware downloads recently, but I’ve seen rare cases here in the Forum where a product manager or developer has engaged with users experiencing a particular problem and has pushed a specific firmware version to a particular MAC address or sent flashable firmware to affected users while they’re trying to debug the issue. I’ve also seen users report that Wyze Support has pushed a particular firmware version to a specific device (again using the MAC address as the identifier), but something like that probably wouldn’t have helped you if your Cam was in an unusable state and not registering online.
:+1:
I’m glad you were able to get this resolved.
Does this mean there is no firmware available for download from Wyze? I have a cam v4 that won’t respond to the usual attempts at resetting and several sources online indicate a manual firmware update with the SD card might work, but I can’t find downloadable firmware. Any help appreciated.
Welcome to the Forum, @duaneross! :wave:
Is that regular Cam v4 or Cam Pan v4? This topic is tagged for the latter, and I’ve never seen Wyze post Cam Pan v4 firmware to the Release Notes & Firmware page, though several downloads are available for Cam v4.
It’s a regular Cam v4
Thanks for that info, I’ll try downloading from that page.
You’re welcome. The instructions you’ll want to use are here:
https://support.wyze.com/hc/en-us/articles/360031490871-How-to-flash-your-Wyze-Cam-firmware-manually#Accordion-wyze-cam-v4-0
You’ll want to be sure to use a 32 GB or smaller microSD card formatted FAT32 for best results. So that I don’t have to try to plug the device in while holding the SETUP button, I usually plug the Cam’s power adapter into a power strip instead. That way I can just hold the button and flip the switch.
Having the same purple light issue with my Wyze Cam Pan v4. I’ve tried unplugging and plugging back in, holding the setup button to reset it, and even holding the button to factory reset it. Nothing worked I’m at the point of trying to manually flashing a fresh copy of firmware but non of your links for the Wyze Cam Pan v4 are active to download the firmware i need. Some help would be nice.
Welcome to the Forum, @ahdonahue! :wave:
Without more specific detail about what you’re experiencing, I’d say that if the purple light you’re seeing is the status light, then that typically indicates an in-progress firmware update, as noted previously. If you’re trying to do a factory reset, then you should ensure that no microSD card is in the Cam so that it doesn’t detect a card’s presence and attempt to do a firmware update (from a file that isn’t really there, because Wyze hasn’t made it available for individual download).
What has Wyze Support said when you contacted them?
I had the exact same issue. I contacted their support online and was told that the firmware recovery image does not exist and they are doing a return on my camera.
I mean, why won’t you answer the questions in general? Is there a way to download the FW? The following link does NOT have any FW for PAN v4: https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware
Usually, the links are hyperlinked to the FW version text, but I think it’s disabled for some reason
Welcome to the Forum, @AbuElMousa! :wave:
I do. I try to give the best possible answers with the information that’s been made available to me.
As I’ve said here and elsewhere in the Forum, I have not seen Wyze make Cam Pan v4 firmware publicly available to download for flashing, and I don’t know why some Cam firmware announcements have firmware download links on the Release Notes & Firmware page and some do not. Other Forum users have been frequently frustrated by this, as well, and I think many of us would appreciate more information from Wyze.
Please keep in mind that this is a “user to user” forum. Moderators, Mavens, etc are not Wyze employees and aren’t paid to help out. While they may have some more insight and contacts than the rest of us, they don’t have anywhere near all the info that Wyze internal people have.
Wyze employees monitor the forums from time to time but aren’t that active in here, and when they are, it will clearly state that they are a Wyze employee next to their name.
