Wyze Outdoor Camera Survey with GIVEWAY!
Hi Wyze friends!
I’m Will, a Product Manager on the Wyze camera team. We’re exploring ideas for our next generation of floodlight cameras, and we’d love your input!
:backhand_index_pointing_right: Take the survey: Wyze Outdoor Camera Research with GIVEAWAY!
As a thank-you, please leave your name and email at the end to enter our giveaway. We’ll select 10 winners in two weeks, each receiving a Wyze product. Prizes include Bulb Cams, Cam v4s, Cam OGs, and Floodlight Cams. Winners will be notified by email.
Thanks for helping shape what we build next!
I took the survey.
It’s similar to a previous survey we took months ago about new entry level floodlights, but this time targeting Pro level outdoor cameras instead of entry level floodlights.
Personally, I LOVE the Floodlight Pro models. They see EVERYTHING, and have free local object detections included and 2K. They’re my favorite camera.
The only things I would consider upgrading them for would be a camera that has:
  • higher resolution
  • a second lens that is telephoto/zoomed in and can pan/tilt to follow the AI objects up close
  • Bonus: RTSP or Home Assistant integration
It seems the first 2 may be things Wyze is considering which I would consider a HUGE upgrade!
Even if this new camera isn’t a floodlight, I would consider putting it in a couple of locations.
If the new one doesn’t have a wife FOV, but does pan tilt lens with telephoto zoomed in, then I would use it together with a Floodlight pro that sees everything while the other one sees more detail up close.
I have been looking for Floodlight Pro model for some friends & clients. The main problem has been the voltage limitation. They are in the 240V regions. Kindly make the voltage to be universal: 110v -240V.
