On the web interface for one camera I get- unable to load this event check internet. My other outdoor camera works. Bothcameras work on phone app. Older events still work. This seems to have started after two changes. I tried to change the outdoor hub to wifi, had to go back to ethernet. Why does wyze keep rolling out features that don’t work except they break other things when you try them? The other change is, I setup a door bell camera.
Seems to have solved itself. Events during the down period still don’t run in web interface. New ones in the last few minutes (trees blowing in storm) are working. The outdoor cams seem to be a source of constant maintenance. Not comforting that I am going on a trip next week and won’t be able to power cycle them and the hub/base. Wired wyze stuff give less trouble.
I don’t have any of the Cam Outdoors, and I don’t use the Web Portal a lot, but I do occasionally see those messages about events being unable to load even on some of my non-battery cameras. I’m not sure what causes it but tend to attribute it to occasional glitches and/or back-end fiddling that Wyze always seems to be doing. I don’t have a better explanation for you.
