Hmm, how many cams do you have on that base? We have 3, and a internet speed of 5 down 3 up, and it doesnt seem to cause any issues. There is certainy a spike in traffic during live view or when an event is being recorded, but never anything huge. Is it just 14 spikes, or constantly?
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
When I did the test here all 3 of my cameras were in a closet.
And no events recorded.
[Mod Edit]
Yes, I have the same problem but my internet is 250 down and 10 up but when the base station is plugged in I get constant spikes where my speeds drop very low. So far my only solution has been unplug the basestation. I tried to put it on my second router that is setup as an access point which I use for my smarthome devices but even there its bogging down my system. Wyze really needs to fix this and if it happens to some but not others I would say it has to be wyze has faulty hardware.
I’ve been using the same base station since October 2020. Basic Motorola cable modem/AC1900 router combo. My House is only 2000 square feet, one story wood frame. Cams are 45 feet, 40 feet, 35 feet and 30 feet from the base. Internet is 100 down 6 up.
I haven’t tried a different base station mainly because you are correct we shouldn’t have to do that, but I’d be curious if that does fix the problem. I don’t really want to put anymore money into wyze at this point. Have you had any success with their support? I haven’t heard anything back anytime I submit something to them.
I think that I might be having similar issues. My post was about the frequency that this system runs on, initially thinking that the frequency of the camera’s were conflicting with other devices on my network, but now I’m starting to think that it is the base station that is the issue.
What did you use to monitor the traffic of the base station?
