I recently go the lock bolt v2 and love it. I use the camera and the app have them all together and very easy to use. I do have two recommendation for the to improve the lock.
When using the auto lock function I suggest there should be a sensor or something in the software that the auto lock should only be activated when the door is confirm close. Right now if you use the auto lock it will activate the lock bolt even when the door is not close and this can be a security issue as the door will not be able to be close.
There is no visual indication on the lock if it is lock as the inside pad is all black. Suggest that there should be a white dot on the lock knob so you can visually see it is lock.
Love your product and look for these improvement soon.
I believe this is a hardware limitation in this product. See this topic for additional discussion:
The interior of my Lock Bolt v2 has an indicator graphic printed on the housing that shows the device to be locked if the latch knob is in the horizontal orientation and unlocked if vertical, but I believe that the printing is too dark and that they should’ve used white or a lighter grey to provide more visual contrast. This is a semicircle above the latch knob itself.
Topics like that are generally submitted to the Wishlist category, and we recommend reading and following the instructions in How to Use the Wishlist as a guide prior to submitting there.
The first one is the bigger issue — a bolt throwing while the door is still open can jam against the frame and strain the motor. A longer auto-lock delay helps for now, so the door is actually shut before it locks. Agree on the indicator too, that dark-on-black printing is easy to miss at night.
