Wyze Floodlight Pro Automation Event is missing a Light Timer
Hey all; i will put this in the wishlist once i get approved. The situation: I have 2 WFP’s - I have an automation that detects a person walking in front of one WFP which triggers the 2nd WFP to turn the floodlight on. ALL Works as expected and is AWESOME ! BUT, I must say- Automation events do NOT follow the Light Timer settings from the Motion settings in WFP - which HAS a light off timer. So… if the Automation triggers the floodlight ON, the floodlight NEVER TURNS OFF!
Wyze needs to add an optional criteria to NEW - > Automation Event - > Device Trigger - : >>> Light Timer (which is actually a Light Off Timer) with 5s~5mins to automatically shut off the floodlight if the criteria is set by the Automation Event.
