I didn’t suggest the use of docker-wyze-bridge or other hacks. You mentioned that you had enabled RTSP on Cam v3 but were unable to stream video into VLC or Blue Iris, so I was suggesting other topics where this has been discussed and where other users have shared suggestions for successful streaming.
Sorry I am not a good candidate to help with data etc. from my v2 and v3 pans They are 15 feet up on poles. I did beging to have the SD card issues once the firmware update was installed but NOT before the update. The V2 is inside an out building but the others are just not easy to access.
Bob
I installed the latest (4.36.16.7064) update:
and I’m stuck again unable to proceed past the disabling of RSTPS. The Accept button is not visible, and I can’t scroll to it:
all despite my default text size is set to normal:
I cannot get VLC or Blue Iris to pull RTSP from it, even if enter rtsps:// in VLC:
or set Blue Iris to port 322. There is a Wyze: V3 RTSP model-specific option in BI, but it doesn’t work even if I change the default stream path from /live to /stream0:
but no explicit rtsps option in the drop-down:
Have you tried using a different device? I don’t use iOS, but even on Android I’ve found that different OS versions on different devices do not always display certain screens within the Wyze app the same way, which I suspect is due to screen geometry and other factors (and probably not correctly coding during development to account for the differences). If I were you, then I’d be inclined to submit a log from the app and then post about this with your Log ID in the Wyze News (or Beta) topic that corresponds to whatever version of the app you’re using and include details about exactly which app, device(s), and iOS version(s) you’re using, because I suspect this is something they might need to fix within the app, and engaging in a more current topic might be a better way to get visibility back to Wyze.
If you think the issue is with that firmware update itself (rather than the app), then you could also post to the topic for that version:
As far as I’m aware, RTSPS is not supported in VLC, as I mentioned above:
I got it working. More details here:
Any updates on the Pan v2 RTSP support?
