Wyze doorbell problem voice command works once then freezes
When you talk any help we be appreciated
Are you referring to the 2 way voice between the app and the doorbell? If so, it could be a indication of a bad transformer as it uses more power with 2 way audio
Thank you for your response I noticed
That who ever wired the chime transformer also tied in the humidistat
For the April air humidifier on the same wire we don’t use the humidifier anymore so maybe if I disconnect it might have enough power what do you think thanks.
ahh yeah maybe they were stealing power for the aprilaire, I’d disconnect it & test
