Wyze cam v4s work for an hour then stop
We have a couple wyze cam v4s that are plugged into a floodlight cam and they always stop working after an hour.
we can flip the circuit breaker and they come back up for a bit.
A couple of v4s into the same floodlight V1 USB port? I take it you’re using a splitter of some kind?
I can tell you that the problem is the same thing a lot of people have had with the floodlight V1 USB port. It doesn’t put out enough power for 2 cameras to remain reliable. They will work for a little while, but then when both need to use up more total power than the USB port outputs, they stopped working. This often happens when there is a motion event or if one or both try to use the spotlight or various things like that.
I confirmed this myself with the floodlight V1 that I had. I was able to get two cameras to work at the same time pretty well most of the time using a sort of USB splitter so that I could have two cameras running off of it at the same time.
However, the effectiveness depended on which kind of cameras I was using. For example, it worked pretty well if I was using OG cameras, but if I used even a single pan camera for example, it would experience the same problems you are reporting. Same thing if I used two other higher power guzzling cameras. And it happened much more often if the cameras used their spotlight which took up more power, or even their IR lights for night vision. Also, if they are uploading cloud events at the same time, that would sometimes knock them offline as well.
Another thing that I noticed when I was doing this is that if the USB cable I used was too long, then the power drop would weaken over the distance so much that when even a single camera tried to use too much power it would lose functionality, let alone if two of them did.
Since you said you are using two V4 cameras on the same floodlight V1, that is almost definitely your issue. It can’t really support to V4 cameras on that weak USB port.
There are some potential workarounds. For one thing, you can kind of change the settings in the cameras to reduce their power draw, such as make sure the spotlight is disabled, maybe turn off the IR lights for night vision and just rely on the flood light ambience to be able to see anything. You could technically turn off motion detection so that the cameras aren’t uploading cloud events, and then just rely on the SD card continual recording and go look around the same time that the flood light camera itself shows there was an event. Event. And then you can look a little bit before or a little bit after on the V4 camera to see what it saw in 2K.
An alternative is to do what I did when I added a floodlight Pro where? I just attached a water resistant surge protector to it that includes USB ports that are more powerful:
