Wyze Cam v4 & Lock Bolt v2 Firmware Beta Test 11/3/2026
Wyze Cam v4 Beta:
Version: 4.52.17.27
What’s New:
  • Fixed a bug that caused frequent device reboots
Note to beta users: For beta users who updated their devices to the previous 4.52.17.32 (beta) firmware, we have rolled back your devices to the 4.52.17.26 (public) firmware automatically to prevent the rebooting issue.
Wyze Lock Bolt v2 Beta:
Version: 1.1.8
What’s New:
  • Improved connectivity.
  • Added a scheduling feature for auto-lock.
  • Bug fixes.
These firmware updates have been causing problems for months. On Android devices, there is still a noticeable 1-second video skip during playback with firmware version 4.52.17.26. This issue has persisted for many months without a fix.
The previous firmware version had finally resolved the problem, but the video skip returned with the 4.52.17.26 update. I do not experience this issue on iPhones; it appears to be primarily affecting Android devices.
Same experience here as well. There is a thread concerning this issue:
Thanks for the info. I appreciate it.
3 V4s are back to .27 firmware. One did not go back, still .32 and a hot mess for notifications and staying connected. It’s outside so I’m not flashing it
Apparently I got rolled back to x.26, and now my spotlight doesn’t work normally.
I have it set up to turn on when it detects a person, and it used to do this very fast. But now it does not turn on when I’m in the room anymore.
I tried changing a bunch of settings and changing them back and tried reset services and seeing the settings back to and it still won’t work. I had to switch it to turn on the spotlight with general motion now, and the spotlight works again, but it won’t work if I tell it to only turn on with person detections anymore.
And I’m still not being offered the option to upgrade to this new beta.
