Wyze Cam v4 - Goes offline everyday during the day
My front porch camera goes offline most everyday, between 9:00 and 5:00. I’ve reset it, rebooted it and done the same with my internet. No one is home all day to turn it off and the backyard camera never goes offline.
The first obvious one is make sure power is not being turned off - timer, light switch, etc. The second possibility is that something else that operates on that 0900 - 1700 schedule is interfering with the WiFi. May be something in your house or it could be a close neighbor. For example a neighbor may turn on a baby monitor every day that is stomping on your WiFi. If you have a WiFi scanner app on your phone, that may give some information (likely not BTW since it is normally only showing the access points, not the client devices connected to them). However what the WiFi scanner will tell you is what channels are being used by your neighbors. Your easiest solution may be to change channels on your WiFi access point.
