Ever since this update 4.52.17.32, my camera has not been acting right,
Its either off line, or just not recording motion or people
That’s to be expected with Beta firmware, and what you signed up for when you enrolled in the beta program. You should report any bugs in the beta thread.
So 17.32 is beta? Can we revert to Production/Release then?
FYI OP I just made a posting about the exact same problem
Yes. Last production firmware was in September 2026 4.52.17.26
You can download it here and flash your cam manually or get out of the Beta.
https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware#Accordion-wyze-cam-v4-firmware-39
I haven’t participated in the beta program but if the app lets you, and you have more than one v4, maybe pick one for beta, and leave the other one as production. That way you can test new stuff but also have a stable cam to compare to.
Alternatively you can turn off automatic updates and pick just one cam to update first, let it go for a few days, and update others if all is well (that’s what I do with production firmware releases).
I have a spare so will do this
thank you
So, nearly a full day/night without RTSP set, not one single drop out, offline, freeze etc.. I have also set up RTSPS on a test cam with previous release FW.
Will keep monitoring.
I wish they would make 4.52.9.6119 (March 23, 2026) available for download! I’m sick of all my v4 videos having stutter in them. People in the BETA program told WYZE that this issue was there. WYZE didn’t listen and released the current firmware which has some BETA participants wonder why they even provide feedback.
Edit: I just created my own URL and was able to download the version mentioned above. I’ll put it on my driveway cam this weekend since that one doesn’t require a ladder to access.
https://download.wyzecam.com/firmware/v4/recovery_wcv4_4.52.9.6119.bin.zip
I see you already found it though.
Yes, I didn’t post it because once upon a time when someone shared URLs to previous versions of firmware, WYZE ended up taking it down. Such a helpful bunch.
Unfortunately the trick doesn’t work with newer firmware, only the ones that used to be downloadable then got pulled off the site, so around March/April.
If it is in GREEN type you can download it from that page, if it is black type you can’t. I think I have downloaded and saved to my PC almost all the V4 firmware versions just in case I need to fix something after an update. ![]()
Actually, the version I downloaded is “black” as you say. If you create your own URL you can usually download the firmware even though there is no link for it.
As mentioned, I have seen WYZE make the firmware unavailable for download after people mentioned this in the past. Not saying they always do it, but I have seen them do it.
I haven’t tested every one, but when I was toying with the v4 and Panv3 ones both stopped working with versions after around March. I didn’t try as far as September.
I’m guessing that September one might go green after they’ve finished the phased rollout, so the file is actually there, just not linked yet. That’s how it has worked in the past with the phased ones.
It seems like maybe there was some concern with rolling back certain firmwares from over the summer, maybe related to the CVR feature that was added or some other security change they made. Maybe risk of bricking cams or something.
Update. 3 days in and everything working absolutely fine with release firmware and no RTSPS on 2 V4’s and 1 V4 with RTSPS.
I will not be updating to the beta.
