Wyze Cam V4 Can’t Stop Notification Audio
Just installed v4 camera outdoors and it audibly sounds the Do Do Do Doot sound outdoors. I want it to be stealth mode and not key the world they can be watched. Wyze Tech Chat says no way to stop outdoor audio.
It does this when it detects a motion event? Is your warning warning set to Wyze tone?
Disable that setting.
Too bad there’s no way to stop the notification sound on the Wyze cam speaker. Did you try taping up the speaker grill? I wonder how much it would reduce the volume?
You should be able to turn it off in the app. Have you checked the setting there?
