Hello,
I need to report that the exact same issue has occurred again with both of my Wyze Cam v4 cameras following the latest app update.
This is now the third time I have experienced the same problem.
The behavior is very specific: the cameras can detect Wi-Fi networks that are very far away, including neighbors’ networks with weak signals, but they do not detect my own Wi-Fi networks even though the routers are very close to the cameras.
This is the same behavior I previously reported to you, and it was resolved after a later Wyze app update. The issue then returned again after subsequent updates, and now it has happened for the third time.
Since both cameras are experiencing the exact same behavior at the same time following an app update, I strongly believe this needs to be investigated as a recurring issue involving the Wyze app, plugin, or the interaction between the app and the Wyze Cam v4 firmware.
I have already gone through the extensive troubleshooting process with your team during the previous cases, so I do not want to repeat the same steps unless Engineering has identified a specific new reason for doing so.
Please review my previous tickets and the history of this case. The previous correspondence clearly documents the same issue and how it was resolved after an app update.
I am attaching screenshots showing the current behavior.
Please escalate this to the Engineering Team as a recurring issue affecting Wyze Cam v4 after app updates, rather than treating it as an isolated Wi-Fi or router problem.
I would appreciate it if you could also document this recurrence so that future app releases can be tested specifically for this Wi-Fi network detection issue.
Kind regards,
