I have four v3 cameras. About 2 weeks ago one cam went offline. I followed instructions to reset (simply unplug and replug). Came back online for 2 minutes and back offline. Nothing works to get it back online. Am I going to have to find a youtube video for a fix or do I trash it and go with another brand? I recently bought a pan cam but am not certain I want to hook it up. There are other issues with the Wyze app but will post those later.
If the cam is located outdoors, look for corrosion where the USB cable plugs into the v3 pigtail. You may need a magnifying glass. Or just blast it with WD-40 and work the connection a few times. If it works, clean the connection with alcohol or contact cleaner, load the connection up with dielectric grease and seal with silicone tape.
Interesting that was your failure mode. I have a bunch of V3 cameras that are outside (mostly under eves), but a couple completely in the rain, and have not had any fail from water getting into the lens.
Modem? Not all router issues affect all connected devices. Sometimes, only one or a selected few are affected. At any rate, how long does a router reboot take, compared to posting these things and waiting for responses?
Sorry you feel that way about wyze. I was shopping around for home camera an I bought wyze because of who the owners are how they started the company basically the American dream blue collar workers , they worked for one of the largest companies. Any way I get frustrated as well with the camera as well sometimes it it’s not the camera it’s me🫣 you might want to give them some more time before you buy something else
