Your assumption is correct, this is EU. If the case is that only 1-11 channels are possible then v3Pro is different from previous models, v2 and v3 can connect via any channel supported by AP/router. However … I bought 2 cams and the other one is being used by my friend - he never had situation like this - 12 channel works fine (cheap router, just 2.4GHz b/g/n mixed mode) - how would you explain that?
The cam types must be different. I haven’t tried v2 on anything other than 1-11. I did try v3 Pro yesterday on 12 and 13 and got the same results as you.
Took some time, 2nd piece works same way ( friend had messy wifi and this was misleadning showing 12ch in use). So yes, v3Pro is bit diff in this matter.
Maybe there will be something new and stunning this morning PST Cheers!
PS.
My old v2 with sense bridge is now 4y old and still working.
