Wyze Cam v3 Pro firmware - Released 3/6/2025
:disappointed_face: Welcome to the forum, that is not good news. I only have one V3 Pro and I did not do the update. Maybe (Someday) WYZE will come up with a fix ?
I have 21 Wyze cameras. They all freeze up from time to time. I’ve had to reset many. 5 cameras I had to replace (13 months old…conveniently out of warrantee). Yes…I’m beyond pissed!!!
I have 14 cams, only one V3 PRO. The rest are V3, V4 and some 4.5 year old WCO v1 cams. One of the V3 cams is only good for close up viewing so I call it OOFO (Out of Focus) I just put it in my garage to see if I remembered to close the door.
Well, my wyze3 cameras stopped working. I tried ALL troubleshooting options.
V3 or V3 Pro cams? All of my V3 cams work, some are 3.5-4 years old.
Additional Information.
When I tried to flash firmware, LED has emit purple for a moment (about a few second),
but return red soon. After over 5minutes. it seems not to be done.
So, I unplug and recognize to PC. The SD card is file system crushed. this phenomenon is every time.
I tried to another (older firmware), but it cause same result.
in this incident, It may be serious trouble in this firmware or hardware.
Regards,
Yuka
Same issue, nothing fixes it. So, I assume we are all out of luck and the only option is to toss the old camera and buy a new one. Nice!
I wouldn’t buy a new V3 Pro, it would want you to update to the Killer firmware. :laughing: Get a V4, they cost less and work just as good as or better than the V3 Pro. I have both The V3 Pro and the V4.
Good advice. I liked the V3 but my other V3 keeps saying 'Update, Update. I canceled and said don’t remind me. I will take a look at the V4. I wonder how many thousands of V3’s are now junk. Good way to get us to buy new camera’s :zany_face:
My V3 Pro works just fine, I have the firmware auto update turned off on all cameras and I did not update the Pro when I read what a mess the firmware created to others.
I think this is key. I do this where possible, as well.
Doesn’t look good for Wyze when people have to do this to protect themselves.
My v3Pro’s updated without issues a week ago. All has been well since. Suddenly, today around 6:30 p.m. edst, 1 of the v3Pro’s stopped connecting and began displaying error code 3005. Regardless of what I tried, I have not been able to reconnect and get past the code 3005. I have not tried a factory reset or flashing an earler firmware version. A second updated v3Pro is still performing normally.
At this point, I am torn as to what my next steps should be. In the meantime, I replaced the cam with a v4 but prefer to have the v3Pro back in service. Do I wait until the issues with this update firmware are resolved or should I try to flash an earlier firmware version.
All advice and comments are welcomed.
I tried all recovery option, but it can not recovery.
Please contact Wyse support, it may be apply guarantee. (replace or return)
I bought Amazon.co.jp (not Authorized store), but Amazon.co.jp accept return. (1 year guarantee)
I will buy Wyse Cam V3 again, because it is available to buy at amazon.co.jp.
If you replace/buy another product, it is recomended Wyse Cam v4. cheap &
Excellent functionality.
Anyway I’m tired on this incident.
Regards,
Yuka
You brick our out of warranty cameras, which renders them useless. Then you say “sorry, out of warranty”. Can you see why buyers are pissed!!! And you’re no longer a trusted source!
Hopefully, I am not going to jinx myself, but I am the recipient of unexpected luck. After being disconnected overnight. I turned my v3Pro on this morning and turns out it has not been bricked from the update. It is operating normally and I am dumbfounded based on yesterday’s failure.
I couldn’t understand the failure to begin with since it operated for over a week with the update and my other updated v3Pro’s stayed online and continue to work normally. So as I stated at the start, I hope I am not jinxing myself. I’ll leave the replacement v4 up for awhile before switching back to the v3Pro or maybe not press my luck and leave things as they are.
Hard to believe the v3Pro is out-of-stock on Wyze and on Amazon more than twice the price I originally paid (tariff impact?? or supply and demand effect??).
:rofl: Of course they are out off stock, they just killed a bunch of them off with the March 2025 firmware. Move on to the V4 until they kill that with a firmware in the near future.
I have four WCO v1 cams that have not worked correctly (Cooldown Setting) since the November 6 2023 firmware update.
