I had this cam in the garage and it worked great for a few months. I recently moved to look out an upstairs window. I had no problems there until a firmware upgrade (4.9.2.42). Now it will connect and I see live video for 2-3 second then it freeze and tries to reconnect. Sometimes it will and others it just fails with error code 0. It suggests exiting the app and retrying…which sometimes I can re-connect and others I get error code 0.
It’s remote so I can’t reboot the router (the other suggestion) but will try that later. The other interesting is that it will let me turn off the camera when it says the connection failed. I can then turn it back on and connect again for a few seconds. Wifi strength is 81% so that’s not the issue. iOS client is 1.5.51. Any ideas?
