Exactly my experiance, I tried bulk update twice, and even the update button on the firmware screen.
The V4s didnt update that way at all, but the pan and the v2 did.
The v4’s had to go to each individual feed of the cam, where it imediatly told me there was an update, and two more confirmations to get them to update each.
One of two Cam V4 issues after update: shutter constant restarting, takes multiple tries to load livestream, error 3005, timeline jumping around to random points on its own, multiple motion events of nothing, turns itself back on after turning off in app.
Cleared cache in app and outside app. Reset services. Power cycled. Restarted. Reset. Restarted whole network.
Other V4 working as expected, except for slow loading of livestream. Updated each cam individually since bulk doesn’t work. Hoping firmware didn’t brick the one V4.
Hi @Dihydrogen , could you please submit a log from the affected Cam v4 after reproducing the issue and share the Log ID with us? We’d like to investigate this further. Thanks!
I am experiencing the same issues as Dihydrogen. The new 4.52.17.32 beta firmware has affected all of my v4 cameras. You can hear the cameras clicking every 2-3 minutes. They are constantly losing connection. When I try to change any settings on the individual cameras they lose connection and I get the “Loading livestream step 1 of 3…” loading screen. This has only been a problem since the latest firmware update. Very frustrating.
Hi @jaymust , could you please submit a log from one of the affected Cam v4 cameras after the issue occurs and share the Log ID with us? We’ll take a closer look. Thanks!
I have noticed an interesting behavior from the affected V4 vs the less affected V4. The affected V4 shutter clicking is happening only during the daytime, so I think that the sensor is trying to recalibrate itself. Have you noticed this too? The affected V4 faces toward the Sun’s direction although it is shielded partially from direct light. The less affected V4 faces away from the Sun. Not sure how this would affect the connectivity issues and the error code, but it is a clue at least about the constant shutter clicking. Both cameras face the same dynamic urban environments with trees, people, cars, etc., along the same axis within 6 feet of each other.
Could we please get an update on the timeline for the **"Change Wi-Fi
Network without device reset"** feature on the **Wyze Cam v4**?
This feature is working on the Cam v3 (since 4.36.16.5654), Cam Pan v3,
and Cam Pan v4 (4.70.2.3661). However, on the standard Cam v4 running
the latest beta firmware (4.52.17.32), the in-app `[Change]` button
under *Device Info → Network* is still greyed out / displays *"You will
need to update the device firmware to use this feature"*.
For outdoor cameras mounted high up on ladders and eaves, having to
physically climb up and press the setup button just to update Wi-Fi
credentials to a dedicated camera SSID is very difficult.
Is support for the in-app network change daemon planned for an upcoming
4.52.x beta release? Any update would be greatly appreciated!
I feel ya.
I havn’t set up vlans dedicated iot/camera network.
But when I do, my current one that EVERYTHING is on at the moment will become the iot/cam network because of this.
I kinda doubt light bulbs, plugs, switches, etc are ever going to get that update.
Way easier to change my few tvs, computers, etc… to a new named vlan.
One V4 acting weird here. Drops offline. I’m kinda waiting for an other update. I have another brand to replace it with already. Patience test on whether new firmware is coming soon. Constant motion detected is getting old on all cameras. Reset doesn’t do squat.
I am getting same now with constant motion and erroneous person detections on both V4s. I also have them frequently going offline. And now my other V4 is also shutter clicking due to a sunnier day. There’s obviously something wrong with the server that handles AI detections, and separate issues with the shutter clicking resetting itself due to light changes and power/Wi-Fi management.
The V2s i have 4, seam to be working better. The choppy upload of events has improved but is still there on all of them, just not as bad. Get to see most of the event recording now instead of skipping over it. This still happens on the upload to cloud and on the playback of events on sd card. Using android on latest beta firmware.
If you haven’t, try going into each individual camera and updating from there instead of the bulk update in the account settings. For some reason, some cameras in beta won’t bulk update but will individually. Clear your internal app cache, then force app stop, clear app cache, then go into the camera and update. Don’t leave the screen until it’s done. Also, make sure the app is up to date.
