Hi G!!! Your Hawaiian Connection here AKA toesreef, if you could let me know the best way to email you I referred a customer and the customer just gave me a report that i would like to change the results for.
[Mod Edit]
BTW… im loving all the products to date, really looking forward to the big vacuum and leak sensors,i live on a boat and that will be a great addition
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
Sorry for the inconvenience. Could you PM me your device’s MAC? You can get the MAC via selecting the device on the App home screen → setting → device info. Thank you very much.
I did a firmware update the other day and now my camera is off-line. I did not want to change it to a WebCam if that’s what I accidentally did. my app is up to date. I power cycled the camera. What do I do now?
I have one camera that wouldn’t download this firmware. I’ve tried to get it to download for a week now. My other six cameras downloaded fine, but my 7th won’t. I contacted Support and got the usual “Help Center” response, which was relatively useless. I’ve had support issues in the past…like when Wyze first started up back in the day. I’ve found that Support has zero tolerance for us “old people,” but that’s okay, they will be old too someday…if they make it!!! Anyhow, is anyone else having an issue trying to follow the rules, which don’t help me at all, and get the firmware in a belligerent camera???
“ Device is off-line error code 90 check your Internet connection or power cycle the camera.” LED on front of cam is amber-ish. I’m now having trouble posting this reply. App is confusing.
Hey Bindi, sorry for the inconvenience. Could you check if your App version is the latest (2.22)? If your App version is the latest, could you get a SD card log before powering cycle your device and PM me that file? Thank you so much.
To get the SD card log, you can pop out the SD card and re-insert it into the camera. After two chime sound you can take out the SD card. On a PC/Mac with a SD card adapter, please put your card inside and send me the log_XXXX.txt file under SD card root directory.
The app version in my iPhone XR is v2.22.21. I don’t know what the hell you are talking about when it comes to powering down some cycle!!! My patience has grown severely thin with this camera!!!
Don’t I need a USB SD card thingy to read an SD card on a desktop PC, which I don’t have and am not running to the store to get??? I’M ON A DESKTOP PC!!! I DON’T HAVE A USB SD ADAPTER, just the regular SD card adapter!!! Is there anything else that you DON’T UNDERSTAND??? THERE IS NO PLACE ON MY DESKTOP TO “PUT AN SD CARD ADAPTER IN TO!!!” I DON’T HAVE A USB SD CARD READER!!!
Donald and Dog (Who is also losing his patience!!!)
With Android App 2.22.21 now installed and running on an Android 5.0.1 phone, will I be able to upgrade the FW on the V2 camera to 4.9.7.798 and the Pan to 4.10.7.798 without loss of function? Or would upgrading FW to 4.x.7.798 be incompatible with App 2.22.21 on an Android 5.0.1 device?
