Wyze Cam reset time
Camera (V2) is awesome. Camera stationed at front door aimed at sidewalk and yard. When we take our dogs out the camera records the event. We are out of site of the camera then return, however the camera does not record our entry. Is there a specific time lapse between event recordings and if so can this be adjusted?
Yes and No
When an Event happens the cam records for 12 seconds to the Cloud and then takes a 5 minute rest.
The rest time can not be adjusted at this time.
BUT
You can put an SD card in and get continuous record. Or 1 minute record.
And in Beta they are testing Continuous Motion Capture which will have a variety of options.
Thank you.
