Most of the firmware is here:
The Pan Firmware goes back to 9/27/2022 on here. Older firmware is available but you may have to search for it. Which one do you want?
I figured I would have best luck with Wyze Cam Pan v1 firmware in 4.10.7.xxxx or 4.10.6.xxxx. I will give anything a trial. Customer support says they can’t give me old firmware and can’t help me. So, this is last ditch effort
Update: Found 4.10.6.218 on the interwebs and no change in behavior. Straight from brand new in box to trash.
OK…so lots of people reporting this…I just searched these forums and this is the same root cause in all of these,
Sounds like Wyze has no fix for this. Giving up at this point.
There are many small details that may get overlooked or unrealized when flashing firmware that can potentially keep the cam from updating to the firmware on the card. I have flashed firmware to dozens of cams many times over during diagnostic and functional hardware and firmware testing. I have had many cams fail to update on repeated attempts. None were bricked. All were able to be recovered. I have only had the displeasure of ever needing a warranty replacement on one single cam out of the dozens I have installed and have never had a cam fail yet because of a firmware issue. It was a PanV3 with a bad motor.
One of the cams I have flashed multiple times and ran every version of firmware and Beta firmware for the last two years is a Pan V1. It is still operational and used daily.
I can’t tell you what is wrong with your PanV1, but it sounds like it never got the full update or failed mid-install. Regardless, there are some things to remember when flashing firmware:
You posted 4 hours ago that the cam was Brand New. That being the case, it should be eligible for full warranty replacement. Have you contacted Customer Support and requested a warranty replacement for the cam?
Thanks SlabSlayer. I appreciate the detailed response.
Full transparency: I have a lot of experience in this field being an EE that works on many embedded systems, and active in upstream community on multiple Arm based projects. Not boasting…just letting you know I am in this business. I truly believe this unit is bricked beyond repair (unless you have a JTAG and lots of time). It is brand new in box. I bought it over a year ago and I honestly forgot about it. I went to use it last week, and it worked initially, and requested a firmware update immediately. I let it take the latest update. It has been dead since. I have contacted support 4 times and they cannot help and promptly told me its already out of warranty. Like I said, brand new in box then (almost) straight to trash. Used for about 30 seconds in total before bricking. Sorry if that’s harsh, but that’s what happened.
I really do appreciate the suggestions. I honestly can’t think of what else I can try. Please note that the manual flash process starts with the LEDs turn blue/yellow indicating it’s starting a flash (so I believe the file system, microSD card and file are probably OK). It then reverts to solid yellow and stays that way.
The only other alternative I can see here is to de-solder the SPI-NOR flash at U2 (GigaDevice GD25Q127C) and try to manually flash it in a programmer (along with an exercise in mapping firmware to blocks). That seems like a lot more work than I have time to invest. Time to move on.
I’m having same issue. First weird stuff started
Happening. The camera would turn on by itself. So I started leaving it unplugged. When I replugged camera back on nothing would happen. I couldn’t get it to reset nothing. So I deleted device to try and reinstall. All I get is solid yellow light. Can’t get it to do anything Tried resetting the reset buttom various different ways. Nothing. Had camera since 2019. Not issues until latest firmware upgrade. Going to throw Cera away and buy a different brand So sick of this complicated camera issues and incompetent help people who don’t know how to help.
Same issue with many Wyze cams. I keep returning them to Amazon. Somehow sometimes firmware upgrade works and sometimes it doesn’t.
The level of incompetency of Wyze Engineers tells a lot about their security…
It just happened to me today. So frustrating to have the camera working fine and it dropped dead after upgrading. Why have updates available if they just kill customers products?
That makes no sense!
There is currently a service advisory.
Wait till they fix it and try again. It should come back up when they fix the service issue. The Firmware update is unrelated, it just causes the camera to restart and when it restarts it can’t come back online no matter what firmware version someone has. They’re working on it.
I have the same problem, but with a wize cam v2.
Cam Pan V1 was fine until firmware update and now it is solid yellow and clicks a few times but does not spin or do anything. Now what?
I hate to be bearer of bad news, but it’s trash now. It can’t be recovered (unless you invest a lot of time and connect a jtag debugger) although many have tried.
Well that just sucks
Hi, I have the same problem with my CAM PAN. All I get is a solid yellow light. And I have a 64 GB SD Card and I still cant flash the firmware. Any Idea? With the 64 SD, when I format the SD I can choose from a variety of Allocation Unit Size. Can this make any difference?
so where do we stand with hardware that has been bricked by bad firmware?
I don’t want to bin it, it was working fine before.
Some people have found that flashing firmware works best with 32gb cards. The Wyze website now recommends this.
Probably not. The bigger the allocation size, the faster read/write speeds you get at the expense of the potential for more wasted (unused) space. I believe there default for 64gb is 128kb. Default for 32gb cards is 16kb.
Since Wyze recommends 32gb cards for flashing attempts and they use smaller allocation sizes, I can’t see how a larger allocation size would make things worse when it just means being able to read the card faster with the downside being potential for wasted space. I wouldn’t worry about the allocation size too much.
For anyone else having issues here. I had a friend whose Pan V1 died after recent events. It turned out he had 2 issues.
Same issue happened to me. I am unable to update to any of the supplied firmware after the camera was working and failed to successfully update firmware via the app.
