Wyze Cam Pan v3 – microSD Format Failure on Firmware 4.50.17.25 (Factory Reset + 2 Verified Cards)
Hi Wyze Community,
I’m experiencing a persistent microSD detection and formatting failure on my Wyze Cam Pan v3 running firmware 4.50.17.25.
I’ve performed several controlled tests to rule out defective cards, filesystem corruption, and camera configuration issues.
The problem
The camera detects an inserted microSD card but reports that it is unsupported or incompatible. When I select Format in the Wyze app, the operation fails.
The camera otherwise operates normally, including live streaming.
Test 1: 64 GB microSD (exFAT)
  • MBR partition scheme
  • Single exFAT partition
  • Successfully verified read/write access on macOS
  • Filesystem integrity verified with fsck_exfat
  • No structural filesystem errors
Result on Pan v3: Card incompatible; formatting fails.
I removed the card and verified that its filesystem remained intact.
I then inserted the exact same card into my Wyze Cam v4, without changing anything.
Result on Cam v4: The card was immediately recognized and began recording successfully.
Test 2: 32 GB microSD (FAT32)
I prepared another card specifically for compatibility testing:
  • Capacity: 31.9 GB
  • Single FAT32 partition
  • Successful 100 MiB write/read verification
  • SHA-256 integrity check passed
  • fsck_msdos -n reported no orphan clusters or structural errors
Result on Pan v3: Card incompatible; formatting fails again.
After two failed formatting attempts, I examined the card again on macOS.
The MBR, FAT32 filesystem, and volume name were unchanged. No orphan clusters or filesystem corruption were found, and no Wyze recording directories had been created.
This suggests that the formatting operation may be failing before making significant changes to the card.
Test 3: Complete factory reset
I removed the microSD card, performed a complete factory reset, and configured the camera again.
I then reinserted the same verified 32 GB FAT32 card.
Result: Exactly the same failure.
The camera detects the card, reports a microSD error, and fails to format it.
Firmware information
  • Camera: Wyze Cam Pan v3
  • Firmware: 4.50.17.25
  • Wyze app: iOS
  • Camera otherwise functional: Yes
  • microSD recording: Not functional
I understand that recent firmware releases have addressed microSD detection and formatting issues, but this problem remains reproducible on my device.
Questions for Wyze and the community
  1. Has anyone experienced this exact issue on firmware 4.50.17.25?
  2. Has anyone successfully resolved it by downgrading or manually reflashing the firmware?
  3. Is there a specific firmware version known to restore microSD functionality?
  4. Can Wyze confirm whether this is a known unresolved firmware issue?
  5. Are there diagnostic logs that could help distinguish a firmware problem from a hardware/controller failure?
I’m particularly interested in hearing from users who have actually resolved this issue, rather than suggestions to try another card or reformat it, since both possibilities have already been thoroughly tested.
I can provide additional technical details, terminal output, and screenshots if helpful.
Thanks in advance!
Camilo Rosero
So far there is only one thread where a solution has been posted. The solution involves working with WYZE support until they agree to send you a replacement camera. Of course, your camera still has to be under warranty for that to happen.
Good luck, as there are dozens of threads with people reporting similar issues with the cam pan v3.
I continue to be amazed that people can’t even make a forum post without using AI now.
Nobody wants to read 2 pages where a paragraph or few bullets would have done, and who knows if the information provided is even accurate.
Thanks for the feedback.
Yes, I used AI to help organize the post, but all the tests and results are real. I personally tested two verified microSD cards, checked their filesystems on my Mac, confirmed that one works in a Wyze Cam v4, and factory-reset the Pan v3.
I agree the post could have been shorter.
@Known1, thanks for the information. Unfortunately, my camera is likely out of warranty.
Has anyone actually tried downgrading or manually reflashing the Pan v3 firmware to restore microSD functionality? That’s the specific solution I’m trying to investigate before giving up on the camera.
thanks for posting such detailed information.
unfortunately it’s a known issue that wyze has been unable or unwilling to fix.
hopefully we get something, someday. There are plenty of posts here and reddit with the same or similar issues. I’m on my 2nd busted pan cam v3.
Since the same card works fine in your V4 and a full factory reset on the Pan v3 changed nothing, that points more toward the camera’s card slot or controller than the card, though I can’t say that for certain. I’m not aware of any supported way for users to downgrade or reflash Pan v3 firmware, so I wouldn’t count on that route. What I’d do is open a support ticket from the Wyze app (Account > Help & Feedback, then submit logs right after a failed format attempt) and mention the V4 test and the factory reset. Those details help them tell a hardware fault from a firmware bug, and if it is hardware they can usually offer a replacement or warranty option. Also worth checking that the camera isn’t on a beta or older firmware than the current release.
The only manual downgrade option right now is a March firmware (which has RTSP and the initial SD card “fixes”, but not the most recent one). There is also one from before RTSP.
I sent you a DM about this.
Please be aware that log submission from the app and Support ticket creation are two separate processes and generate two different numbers (Wyze Support Ticket # vs. Log ID), and don’t expect a response from Wyze if you submit only a log from the app.
Welcome to the Forum, @roserocamilo87! :wave:
As others have noted, microSD card issues with Cam Pan v3 are a longstanding issue, and there are multiple Forum topics discussing this, which you can find via search, though that may be unlikely to resolve the problem you’ve described here.
any idea when we might get the nexxt firmware update for these cams?
has anyone downgraded the firmware and gotten functionality back?
No sd card recording or playback since 4.50.17.25 firmware update my 5 pan v3 cams not working properly since. My cams are garbage now. You will get good advertising for this from me. Wyze is out of my vocabulary now and freinds and family who ever I tell too. I want my money back!
Hi @JamesT6 and @frodoo ,
I haven’t tried downgrading the firmware, so I can’t confirm whether that would restore microSD functionality.
My Pan v3 is also running firmware 4.50.17.25 and consistently fails to recognize or format verified microSD cards, even after a complete factory reset.
Frodoo, I’m curious about your five affected cameras. Are they all showing the “incompatible microSD card” or formatting error, or do they recognize the cards but fail to record or play back footage?
It would be useful to know whether we’re experiencing exactly the same issue.
We might not get one, according to a supervisor who i spoke to over the phone
Wyze still has SD card issues after All these years :rofl:
might not get another firmware update? That seems unlikely …
@WyzeJasonJ , know anything about this?
Supervisor words were “check back to see if there’s any update and IF theres a solution for this one” . I literally have the call audio saved to my phone and thats what she said
A 3rd party call center “supervisor” knows nothing about what Wyze’s firmware plans are.
…and neither do you, I, or the WYZE employees that lurk on this forum.
I have a feeling Jason and several others have a better idea than us, and considering sometimes they drop bits of info that we see, that means we know more than the call center agents (who know 0 about it).
I highly recommend to purchase extended warranty. Wyze suffer with way too many problems, currently having problems with doorbell as well. Wyze needs to get it together
