This is now the second Wyze Cam Pan v3 that has stopped recording to the internal microSD. The microSD is not detected in the Pan v3 no matter what is done; I have tried all the recommended steps.
This is also the second time this has failed just after the 1-year warranty. This seems very convenient considering Wyze sells cloud storage. This camera was purchased 06/02/2025.
I’ve spent a lot of money on a variety of Wyze cameras and have replaced many due to failure.
I was going to say this error has been reported multiple times in the forum. But this is the first time I can recall it being an ‘AGAIN’.
So I checked my newer Pan Cam V3 this morning and SURE ENOUGH, it had stopped recording. Or at least it seems like it did. There was nothing I could access through the camera on the sd card. I was on 4.50.17.19. I reset the services, and rebooted the camera and waited. Still no recordings available. So I installed the 4.50.17.25 firmware, I think it’s beta, I think it’s supposed to fix a format issue. It installed, I waited 5 minutes and checked and no recordings. So I formatted the card, waited 5 minutes, and NOW there are is a current recording.
So not sure, what happened or why. 99.95% sure it’s NOT an sd card issue!
Seeing a second Pan v3 do this right after warranty is rough. Since others are hitting the same stop-recording pattern on newer Pan v3s with cards that still work elsewhere, it may help Support if you note the exact firmware build and whether the app still shows Format or Local storage options, or the card is fully missing from the cam. That distinction shows up a lot in these reports.
