I have 3 I have three wyze cam pan v3 that are showing errors since yesterday.
The error messages with these cams are fairly generic, have you tried rebooting your router and the cameras?
Another possibility is a power issue may have damaged the power supplies, you could try switching them around to see if that changes anything, but I’d try the reboots (pulling power for like 10 seconds) on the cams and router first.
I have restarted the app, the cell phone, unplugged and restarted the cameras which helps for about 12 hours, I even restarted my Wi-Fi.
If it is a pretty consistent 12 hours it likely means the DHCP in your router is freezing up. Next time it happens just reboot your router/wifi. Nothing else. If that fixes it, your router is likely on its way out. You can factory reset the router and reconfigure it, could just have something corrupted, but that’s usually the first sign that they’re dying (needing to be rebooted frequently).
I appreciate all the insight.
Thank you
