Wyze Cam Pan v2 Firmware Beta Test 9/20/2023
Version: 4.49.11.5859
What’s New:
  • Improved IoT connection
  • Improved log collection for IoT disconnections
  • Fixed a bug that caused gaps in microSD card recording
  • Fixed a bug that caused incorrect LED status when motion detection is turned off
  • Security improvements
You should have it reboot occasionally if it can’t connect. My internet works fine but the camera just stops connecting. I have a reboot command programmed for once per day but I’m guessing this is initiated from the cloud, which is useless when the camera refuses to connect to the cloud. Rules should be in the camera or something. I guess I need to take one of my Kasa plugs and use that to power cycle your camera every day.
