Wyze Cam Outdoor won't charge
the red light is blinking but it won’t charge?
[Mod Edit]: Title modified to enhance search clarity.
The Wyze Cam V3 is not a battery powered camera, the Wyze Cam Outdoor (WCO) is a battery powered camera.
If you have a V3 it gets it’s power from the wall adapter only - Or any Micro-USB 5 volt power source.
V3 Wyze Cam below
Wyze Cam Outdoor below
Its the wireless outdoor version that i charge with an adapter and then use the camera outside…i have two and neither will charge even tho the light is red blinking? What do i need to do to fix this?
Have you tried a different power adapter?
I’m Late to the game as usual. did you try charging with the base station? How old are cameras? what firmware is on the Cameras? Did you fix it?
When charging the light will be red and blinking, have the camera on and connected to your app you can see the battery level with the lighting bolt which tells you it’s charging, that’s how we do all of ours you can’t go by the light on the back its wortless
