The timestamp watermark on my Wyze Cam outdoor video is one hour behind. I tried tricks from this forum but wonder if the issue is base station not having correct time. I tried switching network connections on the base station thinking it might resync with the network so the cam could resync with the base station but no change. Any suggestions?
Just noticed when I play back an event it says Motion at xxx time which time is correct. It’s just the timestamp watermark on the feed that’s wrong.
I don’t know how this got marked as SOLUTION. There has been no solution and no reply from Wyze. Issue still exists. Please?
Pull the power plug for the base and leave it off for maybe 30 seconds, plug it back in. When the LED light on the top is solid blue, bring the camera in next to the base and push the pairing button on the bottom of the cam until it states pairing in progress/pairing complete. Don’t delete anything from the app especially if the cam or base is offline.
Had tried that before but tried it again. Watermark still one hour off (early). Did a Time Sync. No change.
