I recently purchased the WCO starter kit, worked great for 4 or 5 days. I decided to buy the Cam Plus through the app (google play store subscription). And it worked great for half the day yesterday and then I started getting error (06) codes and was unable to playback videos. Occasionally a 2 or 4 second clip would record but 98% of the time it’s error 06. Steps I’ve done to try to fix it (none of which have worked).
Removed Cam Plus sub from the device. That results in a different error code (07) when attempting playback.
Removed device from the app. Turned cam off using the switch. Unplugged the hub. Went through the process of re-adding it to the app and connecting to the hub again. Still nothing.
Deleted all my previously recorded videos (essentially started from scratch).
No matter what I try, the errors persist. I have 2 more WCO’s coming today but will most likely be returning them if I can’t get this figured out.
Anyone know how to completely factory reset the camera or otherwise know of a fix for this?
